Old 26-Jun-2016, 6:27 PM   #4
Since the signal quality is quite good (most times) I was wondering if there is
a solution for picking up WGRZ reliably.
I doubt that WGRZ will ever be 100% reliable, but you might be able to improve the reception if you are willing to spend more time and money on the project.
I know there is a trial and error curve, but I am at a loss as to what to try next.
There are a few things you can try; no guarantee.
Maybe there is another antenna that would be better for me?
With a NM of -10.7 dB for WGRZ, a little more antenna gain might help.
The C4 gain is about 12.0 dBi at 587 MHz.
https://www.antennasdirect.com/cmss_...-sellsheet.pdf
The DB8e is about 16.0 dBi with both panels aimed in the same direction
https://www.antennasdirect.com/cmss_files/attachmentlibrary/Technical%20Data%20PDF's/DB8E-TDS.pdf
The 91XG is about 14.5 dBi
https://www.antennasdirect.com/cmss_files/attachmentlibrary/Technical%20Data%20PDF's/91XG-TDS.pdf
and the 91XG has a tilt adjustment that would allow you to tilt the front end of the antenna up to better catch the incoming signal
