Old 25-Jun-2016, 10:14 PM   #16
All the inside measurements were done without the benefit of an amplifier. The Winegard LN200 that I use is outside on the mast, so all outdoor measurements are done with the preamp. That said I see little or no improvement with the preamp.
It sounds like there is a problem with the preamp. What happens if you go from the 30-2476 directly to the tuner?
