Old 25-Jun-2016, 1:27 AM   #4
Exchangegeek
Thank you so much for the replies and the work you did. Rabbit73 the research you did is amazing. The WSB channel as you indicated is certainly my weakest and it has good days and bad days and I am impressed you found that so quickly.
I did read about airplane flutter but didn't want to draw any conclusions as yet so I saved these images for last. Enclosed, please find two images. One shows the airport traffic during my problem times and other shows airport traffic when I have 100% signal quality. I could still be a coincidence but the limited investigative work I have done suggests it may be flutter.
My limited understanding is that I have a couple of options in respect to a tighter focus antenna or multiple antennas but I am pretty happy with what I have for now.
Do you feel my suspicion is correct and is there anything I can do to make the signal more reliable? I can't get to the antenna anymore but I assume raising it and putting it outside would help. Any other ideas?
Thanks again for all your work and the replies. You guys are terrific!
-Steve
Exchangegeek is offline   Reply With Quote
