Old 20-Jun-2016, 2:27 PM   #13
Would I be grounding both mast and coax properly if I came off the mast with #10 ground wire and joined it to the coax ground on the grounding block? The grounding block then grounded to the house ground via #10 solid core wire...
I think you are covered with that method, but as ADTech stated, the local AHJ might say NOT. Electricians in my area say that some inspectors (AHJs) can be arbitrary and unreasonable, but their interpretation is the law and must be followed, or the work will not be approved.
