got my cm3020 up, and its good!
ok ,took down the rca800 omni antenna,, and just finished installing the cm3020
i now get 4,7,12,25,30,47,59 and all the sub channels. that is running 100 feet of quad braid coax to the junction box on the house and then probably another 75 feet run going into the house. would the cm3414 distrubution amp help at all,to pull in more or should i get the 7778 preamp?? i guess the cw,,real ch 34 would be the only other one i know that i would like.. my tv found the channel ,, but wont display it ,,it says failed to receive broadcast,, {{{thanks to tower guy and rabbit for the help}}}
