Thanks for this advice, I'm thinking about the HD 7694P. What typically ships with the antenna. Can I assume I'll also need to order a mast at the same time? Any other gear?
Also I currently have a dish mounted on my roof with cable running to my cable hub. Is there a way to use that mount and cable that's already in that position for this new antenna? Or is it recommended to do an entirely new mount?
Thanks again.
