Old 9-Jun-2016, 3:15 PM   #17
The NEC does not require that the coax for an attic antenna be connected to a grounding block connected to the house electrical system ground, but in cases where there is strong interference from local signals (like FM), it might be a good idea. When the coax is not grounded a strong signal can get directly into the TV cabinet and make any filters less effective.
