					Originally Posted by  chloe
				... Moisture at the transformer/F connector may
be a problem--there is no weather boot.  Will inspect when installing cable,
replace  F connector and seal with tape.
Thanks for the advice!
Chloe
 A common mistake is to use vinyl electrical tape as a seal against moisture.  From my 27 years in the telecom industry, I can guaranty it will eventually leak, then hold the moisture in.  I would recommend using coax seal
http://www.amazon.com/Universal-Elec...5814331&sr=8-1  or dielectric grease
http://www.amazon.com/Permatex-81150...5814435&sr=8-5  (Radio Shack might be a source, maybe the home improvement centers too.  Auto parts stores commonly stock dielectric grease, sometimes calling it 'tune-up grease')
Some folks have reported observing some signal loss when using dielectric grease.  I have not, but I respect the source.  When I choose dielectric grease, I use it as a filling compound for the weather boot.  To get 100% fill of the weather boot, I slide the boot a few inches back from the connector, apply a bead of the compound to the coax between the boot and the connector.  Then as I slide the boot back over the connector, all of the air is displaced from inside the boot.
