Bob,
However you orient it, you may want to set it so you can access that 355 heading from the eastern half, VS going CW all the way around. There are just more signals on the eastern side, than you could expect to receive from the western side.
You should rotate the control full CCW until it stops and then full CW, until it stops.If nothing is broken, it should now be in sync.
Don't expect a full 360 from any rotor, because there is a steel limiting pin on the main shaft.
Reason: spelling
