Thread: Tivo
Old 25-May-2016, 1:58 AM   #2
Hello, rocco:
I see you are back again starting a new thread. Your previous thread is here:
Antenna
http://forum.tvfool.com/showthread.p...2031#post52031
and gives this tvfool report:
http://www.tvfool.com/?option=com_wr...8e03737c905de5
Is that report still good, or do you have a more accurate one? Zip code 24084 is pretty big going from US77 to Parrott.
It would be easier for us to help you if you kept all your questions on the same thread.
Some TV tuners are better than the TiVo tuner.
Tell us a little more about your setup; there might be another problem. Maybe we can help, or maybe there is nothing that can be done, but we can try.
Which direction is your antenna aimed?
How long is the coax line from the antenna to the TV?
Are you using a preamp?
Where is the antenna mounted and how high is it?
What stations do you get, by callsign, with the TiVo?
What stations do you get with the TV?
