The HDB4X is definitely not equivalent to the db4e, so the 50 vs. 65+ miles range is pretty accurate & nothing beyond that, on the plus side I don't seem to have FM breakup issue with WTOL 11 that I had with the db4e before adding a line filter, but I'm not sure if anything has changed in the last 5 years that resolved this outside of the antenna. Regardless the local 21 are stabilized with this on the Jmount, I was hoping to reach the stronger Detroit channels but that's not going to happen with the HDB4X.
Reason: typo
