Old 8-May-2016, 12:28 AM   #2
Originally Posted by bobsgarage
If you would post that on the forum for me, great, I'd appreciate it.
The question about the two antennas CM4228HD vs HD7698P was more about wind worthiness. Since the CM4228 can receive VHF Hi (either intentionally or not, some say it does), I thought I could choose between the two.
Also, I will raise the guyed bearing ASAP, but want to have my antenna choices by then. I will order Tuesday. Not procrastinating, just collecting info.
Thanks, Bob
The original CM4228 could pick up some VHF signals because it used a VHF/UHF ferrite core balun, but the new 4228HD doesn't do well with VHF-High channels because it uses a printed circuit board balun.
