Old 3-May-2016, 2:19 AM   #16
corvairbob
i got the quad antenna and found so far i have to point them in separate directions. i have the yagi pointing to the SE and the dipole on the SW of the mast just above the roof for channel 49.X seems when i pointed the thin with both sections to the SE i lost channels and the same the the NE. but when i put one NE and one SE i gained 2 channels for a total now of 16 channels. i may get one more and point one SE and one NE and take down the other units and see if these do any good. if not i can sell one i'm sure as it did do the job. it may be like rabbit73 says the beams are canceling out some of the signal to this bay unit. i will keep you posted when i make more progress as i experiment. thanks so far for the help bp.
corvairbob is offline   Reply With Quote
