Yup. Glad to hear it worked. Pre amps are funny just like antennas. One will work better than another or worse depending upon where and how it is uses. I used a CM 7777 for a while a few years ago in a rural town near KC. But on a whim I switched to a Winegard 8275 and got better results with the Winegard at that location. Signals that were pixelating with the 7777 were rock solid with the Winegard. All depends upon the antenna you use and other factors like cables I suspect.
