Old 25-Apr-2016, 2:20 PM   #11
dustyz
I found this link, and it's very educational for those who don't understand the basics, like me. :-)
http://www.hdtvprimer.com/antennas/basics.html
That page basically says I need a low noise pre-amp with enough gain to cover the signal loss over the coax, and another 10db to keep the Tivo receiver out of the picture. It goes on to say I could boost it another 10db without causing problems @ the receiver.
So, I could in theory, use a pre-amp with a 25+ gain. Wow.
What about one of the Channel Master 7777 pre-amps? Recommended? They have a higher 15V voltage that could transcend the coax without too much drop, and enough gain to compensate for signal loss. Low noise too, at under 2db.
dustyz is offline   Reply With Quote
