Old 25-Apr-2016, 12:49 AM   #11
OK, I think I have the address figured out. TVFOOL has trouble with 1393 s quarterline rd, it only knows 1393 quarterline rd because it uses Google Maps, but the white pages and Bing Maps do know 1393 s quarterline rd.
And it didn't help that I used MA instead of MI for your report in post #9; I corrected it. Sorry about that.
As a double check I did another report using the tvfool interactive map browser here:
and saw that the marker was in front of Port City giving this report:
http://www.tvfool.com/?option=com_wr...5134525ed757c7
I also saw a lot of trees; they will block TV signals.
I have the same trouble with the colors in the report if my laptop screen is at the wrong angle; they are too light.
You should be able to get the green ones with antenna #1 and down into the pink with antenna #3 if its preamp isn't overloaded by strong signals.
If you want to delete your address for your protection, do it, and I will delete it from my posts also.
