Old 24-Apr-2016, 8:56 PM   #6
the report for example show ch 17 for me to be in 3 different locations one at 41 deg true then someone sent me one that shows 337 deg true and then i did it again and get 18 deg true miles of second ring an 7.3 miles then at the same second ring and 11.1 miles then at the same second ring and 6.3 miles so how can that be it is not in a car moving around? and the strength is changing plus the power changes and it is the same station. thanks bp
The most accurate report would be one using your exact address or coordinates, but you haven't done that. THAT is why they are different, because we are guessing where you are! You can do your own report here:
or you can tell me your exact address in a forum Private Message (PM) to protect your identity, and I will do the report.
Then you can tell Flint Ridge what channels are most important to you and he can design a system for you using the custom combiners. It is his idea, so he can carry the ball.
