I have a hard time to believe that since 2011 everything has been fine then all of a sudden she needs a rotor or different cables? I agree that something definitely failed or weakened. If you have no way to test the connections and bypassing the cable run to test that.... you may need someone to investigate the problem. Is there a preamp or splitters installed? There is many variables.
