Old 19-Apr-2016, 4:24 PM   #14
kanjigirl
Originally Posted by Billiam View Post
Fixed antenna? A rotor may be needed then.
BTW. Are you using a good quality RG6 cable or RG59? A good quality cable will take longer to deteriorate than a poor quality cable.
Years ago when 300 ohm flat cable was common, I can recall seeing signal loss develop after a few years of use. Cable had to be replaced about every five to seven years simply because it deteriorates in the sun, cold and severe weather conditions.
Yes, it's an RG6 cable. We'll check into the rotor.
kanjigirl is offline   Reply With Quote
