If you are going to run 100 feet of cable you might want to invest in a good RG11 cable. Will have lower loss. Even a half db to a db on some channels will make all the difference between reliable reception on most days vs. an unwatchable signal on most days. I found that out a few years ago when I replaced a 75 foot run of RG6 with RG11. Made the difference on one UHF signal.
