Moisture at the transformer/F connector may
be a problem--there is no weather boot.
It sounds like you should pick up a new matching transformer / balun when you are shopping for coax.
The antenna you describe matches what I found on a non-Radio Shack web site. It is slightly larger that the HBU-22 I mentioned earlier and if its in good condition, it should provide excellent signal for several receivers. It sounds like a very good choice for your situation.
