Old 15-Apr-2016, 11:40 PM   #34
I have a background in electronics and measurement.
Me, too. Measurements are one of my favorite things to do, as you can see from the signature for my posts.
I did some checking with my multimeter and there is 60 VAC between my PC case and the LCD TV.
Maybe you have leakage current. You probably don't have a Simpson 229 Leakage Current Tester, but you can build a simple circuit to make tests.
http://www.repairfaq.org/sam/safety.htm#saftes
Manual
http://www.simpsonelectric.com/image...9-2_manual.pdf
there is 60 VAC between my PC case and the LCD TV. Both are plugged in to different 3 prong outlets. There is no ground wire on either outlet.
You have two 3 prong outlets, and neither one has the socket for the grounding pin of a 3-wire plug connected to ground?
Please make some leakage current tests soon.
http://www.mdsr.ecri.org/summary/det...px?doc_id=8285
