I don't disagree with you on grounding, as I have a background in electronics and measurement. I just haven't found one yet. As a matter of fact, I found more problems. I did some checking with my multimeter and there is 60 VAC between my PC case and the LCD TV. Both are plugged in to different 3 prong outlets. There is no ground wire on either outlet. This is a very old house.
I'm hoping I will find a cold water pipe just inside the basement by the antenna. Hopefully, that's how the electric service is grounded. I'll ground the coax and mast and then see about the rest.
