Old 15-Apr-2016, 12:37 AM   #2
Welcome, Angie:
Where can you put the antenna, indoors, attic, or outside?
Are you thinking of one antenna to feed all TVs, or an antenna for each?
Your signals are fairly strong and in the same direction from the SE but you are behind a hill. You shouldn't have too much trouble unless there are trees or other buildings in the signal path.
PBS and ION are your weakest signals, and ION is in a different direction, which is a complication.
