Old 11-Apr-2016, 2:19 AM   #21
If you are using the high and common ports and it blocks 13, they sent you the wrong thing or it is defective.
It doesn't need to be power passing if it is between the antenna and the input of a preamp if you use one.
I have never been impressed with that brand; why didn't you buy one that I suggested?
A good HLSJ doesn't block UHF coming in the high port.
