Old 7-Apr-2016, 5:24 PM   #12
chris1379
Before I forget, thanks for the photo; it helped a lot.
I think you have a good chance of getting WOWK with your antenna, if you use an FM filter and ground the coax.
Ant > coax > grounding block > coax > HLSJ or 2 > coax > TV
If that works, I have some ideas to try for WCHS; let me know.
Wow, thank you. That coverage map helps a lot. Where do I find that for other channels?
Would it be OK to ground the HLSJ and omit the grounding block to avoid another connection? I only ordered one HLSJ so I'll see how it does first. I don't think I'll find one locally. I do have a grounding block.
I found this diagramon my antenna. It seems to have more gain on higher VHF channels so that's good.
Guess I'll be waiting patiently by the mailbox.
chris1379 is offline   Reply With Quote
