KCKS-LD is a low power station with towers only 200 feet above the ground. That's part of why the signal strength is so low even through the broadcast tower is only 22 miles away.
What direction does your antenna currently point? My expectation is that it is currently pointed to about 170 degrees on a compass (just east of south). I'd try pointing it directly at KCKS-LD (255 degrees) and see what happens. The rest of your stations are pretty strong and you might receive them off the side.
