Old 1-Apr-2016, 2:26 PM   #5
LNA200 has no switch, the trap is always in. The CM777x and the RCA preamps do have a switchable trap. However, like I already said, you likely do not need and should not use a preamp.
Install your F-connectors properly. The test you did is invalid due to improper terminations.
