If you have some older Analog Tv's. Here are digital to analog converters. Tivax STB-T8 , Alphadigital AT2016 , Zinwell ZAT950A , CM7000 , CM7000PAL. Do not go for other model numbers , as an example the Tivax STB-T9 is actually an older model then the Tivax STB-T8. The Panasonic DMR-EZ48VK will also convert digital to analog. Some new Panasonic Tv's will interface directly with the DMR-EZ48VK , one remote controls both.
