Old 22-Jan-2011, 7:41 AM   #4
John Candle
Tv Antennas and Reception
I agree , your location is truly astounding. All the channels in green are all about the same Strong Signal Strength. And even the channels in yellow are all the same moderate signal strength. All of the channels are LOS = Line of Sight , that means no obstructions are in the way between the transmitter antenna and your receiving antenna. GUM is actually making a little joke about the strong channels and HBU33 antenna. You see , the HBU33 is a very modest roof top Tv antenna and even so it's still almost more then what is needed. Do not install a amplifier unless you will be connecting to 5 or more Tv's. Here is a DVD Recorder , VHS Recorder with a Built In Broadcast Digital Tv Tuner. The tuner has the latest Digital Tuner IC Chips. Panasonic DMR-EZ48VK. Here are online Tv Guides. http://www.titantv.com , http://tvlistings.zap2it.com , http://television.aol.com
