Old 18-Mar-2016, 6:37 PM   #15
shoman94
Originally Posted by Billiam View Post
TV Fool cannot create Geographical Coordinates to use if the Address input brings up "Street Level" data only. You get a precise report for a location if you use the right coordinates. www.propertycrunch.com will generate the proper coordinates if you input a specific address and then those Coordinates can be used in place of the Address for a accurate report.
It gives you the coordinates.... you can place the PIN right on the roof top or exact location you are placing the antenna. At the bottom of the map next to the antenna height is the coordinates. Then you can use those coordinates to create the report.
