Excellent! We'll see what spring brings.
If you have a great picture and nothing you operate is creating havoc on your signal, you should be all set with not replacing everything to Quad-shielded. Not sure how much of an advantage they have to be honest.
I don't know what installing the FM filter backwards will do. Maybe someone else knows. I did however notice that once I installed the Juice preamp in place of another preamp, I did not need the FM filter any longer. The Juice is very resistive to overload. You could find the same thing and it may help your VHF channels slightly as long as there is no interference. It did for my but I did have 2 filters. Worth a try.
I'm a little confused on your chart. I thought RF-23 was a worship channel and IND is actually broadcasted at RF-14?
