Old 11-Mar-2016, 1:17 PM   #45
Blackbeen
A bit of an update, since my last post the CPA-19 started to sputter work again as it did before the total burn out (?) i.e. in the 220 magnetic sweet spot I'm able to put in 27 channels, oddly WHTV Jackson MI https://en.wikipedia.org/wiki/WHTV very clearly most times of the day which boggles my mind due to the antenna direction, station power/location, totally freakish when ch 7 is totally out of the picture.
So anyhow I decided this was enough to get me by so I passed on the Televes but now Solid Signal has the HDB91X http://www.solidsignal.com/pview.asp...source=inhouse
on sale for 35$, being that its such a low cost & could use it conceivably at my future home I thought I'd grab it & put it on a tripod inside the room by the outside jmount since it won't fit on it due the the dimensions. I know it will get questionable results inside but it will eventually get an outdoor mount when I move. I might connect a A/B switch to toggle the present antenna since it pulls in the locals pretty well.
Blackbeen is offline   Reply With Quote
