Old 9-Mar-2016, 12:36 PM   #7
I don't think the HOA rules would allow me to put up a tall mast.
The FCC OTARD says you can go as high 12 ft above your peak, no matter what the HOA says.
https://www.fcc.gov/media/over-air-r...n-devices-rule
(3) An antenna that is designed to receive local television broadcast signals.
In addition, antennas covered by the rule may be mounted on "masts" to reach the height needed to receive or transmit an acceptable quality signal (e.g. maintain line-of-sight contact with the transmitter or view the satellite). Masts higher than 12 feet above the roofline may be subject to local permitting requirements for safety purposes. Further, masts that extend beyond an exclusive use area may not be covered by this rule.
