Old 9-Mar-2016, 12:24 AM   #15
drmenard
I want to thank rabbit73. Everything worked great . I pointed the vhf antenna at station 22 on channel 11 and got 100% signal. Ran that to the join-tenna and ran the DB8e also to the join-tenna, then to the FM filter and then to the JUICE preamp. I moved the rotor and pointed the DB8e at channel 30 and got it with a perfect picture. I did not play with it much after that , but it does work great..
drmenard is offline   Reply With Quote
