Old 22-Jan-2011, 2:03 AM   #1
chloe
Help with reception
Hi,
We have poor reception on several channels (2,6 and 12) most of the time. Channels 8 and 10 usually have good reception unless there is heavy rain or
wind. There is a row of fir trees about 120 ft. from the antenna and a row of pine trees about 70 ft. beyond the firs. Both are between the antenna and the tv towers.
http://www.tvfool.com/?option=com_wr...3cf4658af730bd
Our antenna is Radio Shack 150-0264 installed 5/2009, but the cable is much older. The antenna is about 5 ft. above the roof, a total of 19 ft. above the
ground. Cable run is 55 ft. Indoors we have a Channel Master amplifier
model 3043 with gain of 22dB and a Philco converter box model TB100HH9.
Reception is even worse without the amplifier.
Would you recommend replacing the older cable? Would a different amp be
advised? We'd appreciate any suggestions to improve our tv reception. When the signals were analog, we had excellent reception of channels 2,6,8,10 and 12.
Thank you!
chloe is offline   Reply With Quote
