Old 7-Mar-2016, 7:22 PM   #42
shoman94
Your points are well stated, realistic, and understood. Thank you for taking the time to explain your viewpoint.
I still don't know what to tell someone with strong local FM transmitters other than you are SOL, don't aim a VHF antenna that way, use a UVSJ to limit your reception to UHF, etc.
How strong usually effects the signal when a preamp like the Juice is used? I ended up removing my filters for the FM splitter which I felt helped a little on my VHF-hi channels a touch signal strength wise. Then today I removed it all together. When I used the AD-PA preamp I needed them but when I replaced it with the AD-Juice (Thanks ADTech) I did not need to attenuate the FM signals anymore.
The 2 FM station are 3.2 miles from my home and have a RX(dbm) of -18.9 and -24.4.
