Old 6-Mar-2016, 3:01 PM   #3
shoman94
What happens to WCSH if you aim the antenna directly at its transmitter 347 degrees magnetic?
Maybe, but it is more likely because the antenna is not aimed at the transmitter.
Yes but any higher than 2ft above the roof gives me problems. But it's only that channel.
Why, if your antenna is aimed at 25 degrees magnetic, do you expect good reception of WCSH which is at 347 magnetic? Multipath reflections are more likely when the antenna isn't aimed at the transmitter.
It is difficult to predict the results of moving the antenna; you just have to try it.
That channel is very strong and it falls within the side lobe off the main beam for my C4V. It also falls within the beam of the DB4e and also happens when pointed directly at it. The problem is when I raise it above 2 ft above the peak it happens even pointed directly at it.
