Old 6-Mar-2016, 1:04 PM   #1
shoman94
Metal Roof and multi-path
Attached is a screenshot of my location and tower placement. My problem is I have been fighting a reception issue with one station and is my strongest UHF tower (real channel 44 WCSH) and I've had to lower the antenna to 2 feet above the roof peak to stop the glitches/pixels. It is also aimed at about 25 degrees magnetic. If I rotate it from this location is each direction I have issues with this station and only this station. Last night I watched that station for a few hours and saw it glitch a couple times so I have it pretty good. I'm watching it this morning and haven't seen an issue yet. I'm wondering if I should leave it alone or should I move the antenna to the other end of the peak in hopes I could raise the antenna and strength all my weaker station even though they are currently coming in good. Is what I'm seeing due to it reflecting off the roof? It just seems messed up that channel 8 and channel 13 are also coming off that side of the roof and give me no issues.
Yesterday I tried and DB4e in place of my C4V and has the same issue.
Here is my TVFOOL for UHF@20ft
20ft TVFOOL
Here is my TVFOOL for VHF@26ft
26ft TVFOOL
