Old 5-Mar-2016, 7:54 PM   #19
Our reports are closer now. The distances and azimuths match, but the NM numbers are different.
Looking at the Google map and tilting it, you seem to be in a valley surrounded by hills.
I might send you a PM to confirm your location, but as of now you will probably need to try a high gain VHF/UHF antenna like the Winegard HD7698P in different directions as high as you can get it, and a Channel Master 7777 preamp.
An alternative would be an MCM VHF yagi like the 30-2475 or 30-2476 aimed at a VHF channel like 7 or 12 and an Antennas Direct DB8e with both panels aimed at 21 or 15 to avoid using a rotator. The antennas would be combined with a UVSJ UHF/VHF combiner before the preamp.
It doesn't look very promising; you might have to do cable or satellite TV.
Right now we can get WYMT, This TV, WLJC, ION, Qubo, ION Life, Shop, QVC, Home Shopping Network.
WYMT CBS This TV CH12 NM 6.7 dB
http://www.rabbitears.info/market.ph...&callsign=wymt
WLJC Religious CH7 NM 34 dB
http://www.rabbitears.info/market.ph...&callsign=wljc
WUPX ION, Qubo, ION Life, Shop, QVC, Home Shopping Network CH21 NM 19.5 dB
http://www.rabbitears.info/market.ph...&callsign=wupx
I think you are doing pretty good if the "V" dipole of the C4V is picking up WYMT.
