Your signals are pretty strong and mostly to the northeast. I'd try an Antennas Direct C2V aimed at 46 degrees with a compass.
Attics are funny places for antennas. Sometimes they work fine and sometimes not. A lot depends on the metal & electrical up there and what the antenna is "looking through". If you have regular sheathing and vinyl siding you could be OK, but if it's stucco or brick it's another story. Start with an easy stop for testing with a coax run through the house to the TV. If it doesn't work be prepared to try everywhere in the attic it will fit. Run permanent wires only when all TVs get a good signal.
If that doesn't work you can mount it outside.
