Old 3-Mar-2016, 4:49 PM   #3
is there any rule of thumb to know when trying to get a station if its worth trying a bit more or if a co-channel is just going to knock it off the air.
Off the top of my head, it's around 35 dB at the input to the tuner. for adjacent channels [emphasis added, the factors Tim mentioned come into play for this] This also presumes you are not generating either IMD or harmonics in the receiving system before the tuner that fall into the weaker channel's bandwidth lowering its SNR. For co-channels, I'd have to look it up.
or is this pretty much factored into the results page
It is not factored in at all.
anytime there is a C you are going to get knocked off
No, you have to manage the co-and adjacent signal forecasts separately and manually.
