Tv Antennas and Reception
You have been researching Tv antennas and you have discovered that the market is flooded with scam antennas. The real outside on the roof Tv antennas are from , Winegard , Channelmaster , Antennacraft , Antennasdirect. What ADTech is Not telling you is that there are no perfect alogrithms. I prefer an optimistic algorithm. Not a pessimistic algorithm like antennaweb. I prefer to know what is out there and what I can or can not do to receive the Tv stations. Also what ADTech is not telling you is that it is better to use a bigger antenna , a bigger antenna collects more signal , an amplifier just makes what goes into the amplifier stronger , an amplifier does not create or collect more signal , and the amplifier is additional cost. Turn on the light when it's dark and see what it is. Follow Tower Guys advice. And yes you can connect 3 Tv's
