Old 2-Mar-2016, 4:36 PM   #8
shoman94
Otay, if that happens to be an issue with the property management, then perhaps moving the current antenna and mast assembly to the other end of the balcony so it is not directly against the wall may be of some help.
As long as it's your exclusive balcony. If its shares with other tenants then it is a common area which does not apply to the law.
If you get the landlords permission then you can do anything they allow.
