					Originally Posted by  ADTech
				The green LED on the power adapter indicates only that the adapter is providing power at that point.  It doesn't mean the power is actually reaching the amp.
If you get the same results with the adapter powered as un-powered, that usually means that amplifier is either un-powered or defective and is now a 20+ dB attenuator.
 What does it mean to be a 20+ dB attenuator? and out of curiosity, would the fact that the old inserter worked better unpowered indicate that the adapter is bad or something else?
