					Originally Posted by  ADTech
				I test all returned JUICE amps myself.  Out of about four dozen returned in the last three months, I've found two defective amps, two more that had damaged coax connectors (white insulator had been pulled out), and two defective power inserters, both of which should never have gotten out of the factory (assembly errors).  That's out of about a thousand units sold.
Quite frankly, the bulk of negative reviews are not due to a hardware fault.  They're due to either a product misapplication, unrealistic expectations, or an error in execution.  Of course, it's always the product's fault....
 Well I didn't even notice that The Juice replacement was already at my door, so I hooked up the inserter & plugged it in, happy to see a green light I thought I was good to go & gave my TV a scan, unfortunately, even with the green light on the adapter it scans the same local 20 channels (when working I normally get 40 on a bad night), the only difference with this inserter is it scans the same 20 adapter plugged in or not, with the old one it would actually only scan 9 plugged in but 20 power off, regardless I assume the CPA19 is bad (green light on or not), I wish I could get to the roof to test the Juice but it may have to wait until I move.
