Old 1-Mar-2016, 3:50 AM   #14
shoman94
Looking at those numbers.... I believe you could easily use the DB4e and the dipole's....
So if you are 27' to the peak.... Use a 10' or 12' pipe (galvanized) for your mast. I'd say 1.25" to 1.5" OD.
Mount the dipole at the top and mount the db4e 3 feet below the dipole. It will look similar to my attached photo of my setup. Getting those 2 antennas should save you some money too.
Also, yes the fm trap or splitter would get installed between the antenna and the preamp.
File Type: jpg IMG_20160229_165731602_TOP-768x1024.jpg (110.7 KB, 1645 views)
