Old 1-Mar-2016, 1:53 AM   #11
shoman94
You need to flip one of the baluns. Most likely, you're feeding the combiner/splitter with one loop 180° out of phase which will cause a big, giant dead spot straight ahead with major lobes skewed high and low.
No. The HPBW is explicitly stated as 43° which is it's calculated value at the low end of UHF, it narrows to almost 30° at 698 MHz. Only the major lobe is considered when the HPBW is specified.
Son of a gun! The baluns can be installed out of phase! =(
Is there a way to test the balun prior to installing?
Never mind. I was going to try it but the parts are almost 35 bucks so I ordered a DB4e to try instead.
