Old 1-Mar-2016, 1:10 AM   #9
If you found a Channel Master Join-tenna for channel 11, then it is designed to do the combining for you.
http://www.channelmaster.com/JOIN_TE..._p/cm-0581.htm
What would be the best one for outside use?
The CM Join-tenna is designed to be used outside.
