					Originally Posted by  ADTech
				The JUICE and the CPA19 can use the same power adapter.  Works fine, I've done it numerous times.
If you plug the CPA19 into the JUICE's power adapter and the green LED on the adapter goes out, the CPA19 is defective.
 How common is it for the Pre-amp to burn but over the adapter? I've read quite a few negative reviews of JUICE not working or going bad in a short period of time but its hard to tell if its an issue with the Pre-amp or a shorted out adapter.
